What do you suggest to use for cPanel/DirectAdmin server monitoring?
someshzadesomeshzade Hosting ProviderOG
What do you suggest to use for cPanel/DirectAdmin server monitoring,
I checked Nagios and found its complex for me to configure it.
Nexa Racks - Reliable Web Hosting Company
  • Munin
  • K4Y5K4Y5 OG
    edited December 2019
    HetrixTools?
    I'd rather not waste time in setting up my own monitoring system / agents and then setting up another set of agents to monitor my primary monitoring agents. Life is too short for that nonsense.
    Thanked by (2)LeonDynamic seriesn
  • @K4Y5 said:
    HetrixTools?
    Absolutely agree. Go with Hetrixtools, you can monitor everything from there, setup different notifications to whatever platform you want and away you go.
  • edited December 2019
    All depends on how much information that you want and how much you wish to expose to external parties. The OP was lacking in detail, apart from Nagios. Munin is an appropriate alternative for internal use.
    96.9%
    uptime, according to HetrixTools for a one server which I know is nonsense.
    96.9%
    If you run out of disk space, HT will show you offline if you are using Agent-based monitoring.
    HT can show you offline, even without agents, for http(s),mysql etc.
    With agents/snmp much more is possible.
    Perhaps I should've emphasised my first sentence in the previous post. ;)
    Thanked by (1)someshzade
  • DanielDaniel OG
    Netdata is really awesome. Here's a post I made about it on another forum: https://hostballs.com/t/netdata-awesome-system-monitoring-tool/1662
    It has per-second granularity for all the metrics it collects, so can be extremely useful for debugging CPU usage spikes that only last a few seconds (as one of the metrics it collects is CPU and RAM usage per process, and per systemd unit). A lot of other monitoring systems are only per-minute so they don't catch small spikes.
  • Wouldn't go anywhere near the netdata spyware, after an encounter in CWP.
  • someshzadesomeshzade Hosting ProviderOG
    Thanks to everyone, much appreciate your suggestions.
  • @someshzade
    So, which did you pick ?
  • @AlwaysSkint said: Wouldn't go anywhere near the netdata spyware, after an encounter in CWP
    What's this in reference to? Is there a link/etc to read more?
    In CWP, click on Graphs, Netdata and before you know it, it installs software and sends a heap of data to a 3rd party. Fab. not!
    The act of monitoring implies some performance degradation, so for 1s granularity I suggest the monitoring itself is a consumer of resources. Want to see an example of this in action? Try Windows Task Manager with its' stupid default refresh rate, then decrease it to 5sec. More noticeable on lower CPUs and it only displays a few metrics but the fundamentals are the same.
  • @AlwaysSkint said: In CWP, click on Graphs, Netdata and before you know it, it installs software and sends a heap of data to a 3rd party
    Ah so it's a CWP issue, rather than netdata itself?
    @Rahul said:
    @someshzade
    Kinda confused now.... but taking advice from other experts as well. If you have any suggestion please drop me a DM.
    @Mr_Tom said: Ah so it's a CWP issue, rather than netdata itself?
    Yes, though the type & quantity of data passed to the remote netdata was far too revealing and was enough for me to immediately terminate it. Fine to use external montoring (Hetrix, Uptime etc.) to check for common ports (eg. 80,ping) but best to keep detailed server stats for internal consumption. You could run your own central monitor, if you feel the need for consolidation - I had a freebie VPS doing this duty, for 6 months; only for testing, as it's better than idling, just.
    Note: I am biased having come from an Enterprise Management background.
  • DanielDaniel OG
    @AlwaysSkint said: The act of monitoring implies some performance degradation, so for 1s granularity I suggest the monitoring itself is a consumer of resources.
    I've installed Netdata on several servers and have never seen it use more than 5% CPU. I've even got it running on NAT VPSes, although I decreased the refresh rate to 5 seconds on those (not due to CPU usage, but due to RAM usage). For me, CPU usage of Netdata collecting metrics once per second is actually less than Munin was when I used it to collect metrics once per minute. The core of Netdata is written in C which contributes to its lean-ness.
    This sounds like a CWP thing (whatever that is)... Default netdata doesn't send data to a third party.
    Thanked by (1)AlwaysSkint
  • Might be tempted to take another look at netdata, installing from github. Munin can sometimes get a bit bogged down generating charts but generally I've found it reliable.
  • @someshzade said: If you have any suggestion
    nodequery.com works
