C1V HOSTING - UNBEATABLE VPS & VPN PLANS, FREE GIVEAWAYS
2
  • c1vhostingc1vhosting Hosting Provider
    @localhost said:
    @c1vhosting said:
    @localhost said:
    @c1vhosting said:
    @localhost said:
    @c1vhosting what is the log policy for VPN? I could not find that info in the T&C
    Hello,
    no any particular logging as now.
    If our policy changes (e.g. to comply with future legislation) we will notify you via email.
    wow thats awesome.
    Any third party can audit your claims of no-logging? This will help build credibility in the long term.
    Um, no. We should raise prices to afford certifications etc..
    I am sure people will be happy to shell out more when they know what you say corroborates by a third party - specially in this black box type system. Good luck to you and your users!
    Can you share me a case to study?
    Thanked by (1)localhost
    C1V hosting: Italy's Leading Data Center | Unbeatable VPS, Dedicated Servers, and Colocation | Cutting-Edge Facilities in Pomezia | Where Your Success Takes Center Stage.
    🚀 VPN for €5/year 🚀 | Follow us on Telegram
  • C1V HOSTING IS THE BEST ON LES, GO TO https://www.c1vhosting.it/link.php?id=38
    Thanked by (1)c1vhosting
  • @c1vhosting said:
    @localhost said:
    @c1vhosting said:
    @localhost said:
    @c1vhosting said:
    Hello,
    wow thats awesome.
    https://protonvpn.com/blog/no-logs-audit/
    I am not an expert at this but something similar. Maybe there are some experts in the community here that can chime in
  • @c1vhosting said:
    @localhost said:
    @c1vhosting said:
    Hello,
    wow thats awesome.
    Please give a technical view how you obtain the no-logging
  • i might be a freeloader but why shill?
    All of my VMs: https://nodecheck.net/s/otusibrc/
    thx!
    1U COLOCATION (Low Power)
    Our energy is supplied using exclusively green sources.
    Power redundant 34,5W/0.15A included (24,84kWh/month)
    Port speed 1Gbps shared, 10TB monthly traffic included
    IPv4 1 IPv4 addresses included
    IPv6 /48 IPv6 subnet included
    Basic Remote Hands
    Price: €12,20/month
    Discount code: Y4P16JIUVG
    Order link
    Why Choose C1V Hosting?
    • State-of-the-art data center
    • Sustainable and eco-friendly operations
    • Mon-Sat 9am-6pm expert support
    • High-performance servers with top-tier connectivity
    • Exceptional value for premium hosting solutions
    Useful Links
    ADDED FEATURE: Additional VPN profiles
    You can now order multiple VPN profiles with your VPN service.
    4GB €12/yr NVME KVM - C1V HOSTING
    ROME VPS
    • Price: €12/year (VAT included)
    • Specs: 2 vCore CPU, 4GB DDR4 ECC RAM, 35GB SSD NVMe PCIe, 20TB @ 1Gbps monthly traffic usage, 1 IPv4 address, 1 IPv6 address
    • Order link
    • Discount code: VQLR58CN5U
    • Quantity: 10
      Note: Select annual billing cycle to apply discount.
    Useful Links
    Thanked by (1)bliss
  • edited January 2
    @c1vhosting said: 4GB €12/yr NVME KVM - C1V HOSTING
    ROME VPS
    Double disk space for commenting your order number ?
    How can install from ISO ?
    I get the error msg "CD ROM volume not found" when attempt to install from ISO.
    Attemped to change the "boot device 1" to CD/ISO, option is not available. Only options are "None, Drive, Network"
    Same problem.. Ticket #C1V_8901368_TCUSID opened, but no answer.. I need AlmaLinux 8 for this vps, only debian/ubuntu templates available.. :/
    ROME VPS
    No :(
    Just open a ticket with service id and what iso you want.
    Thanked by (1)bmoto
    Your ticket is being reviewed :)
    ROME VPS
    • Order link
    • Discount code: 1Y3M1ZN4IH
    • Quantity: 10
    Useful Links
    Thanked by (1)bliss
    Thank you. Alma is installed, but network almost died.. :/ Was very bad before Alma install with ubuntu also. SSH-login take long time and shut down without warning. Webmin say "connection lost" and even VNC via control panel can't connect most times.
    Reboot/shutdown/restart not fix a situation.
    Can you check it, please?
  • €12/yr VPS is good friend.
    #             Benchy v2.7               #
    #    https://github.com/L1so/benchy     #
    #        02 Jan 2024 11:04 UTC          #
    Server Insight                                  Hardware Information
    OS         : Debian GNU/Linux 12 (bookworm)     Model       : Intel(R) Xeon(R) CPU E5-2697A v4 @ 2.60GH
    Location   : Italy                              Core        : 2 @ 2596.990 MHz
    Kernel     : 6.1.0-17-amd64                     AES-NI      : ✔ Enabled
    Uptime     : 0 days, 7 hrs, 11 mins, 47 secs    VM-x/AMD-V  : ✔ Enabled
    Virt       : kvm                                Swap        : 0.0 KiB
    Disk & Memory Usage                             Network Information
    Disk (1)   : 34.3 GiB                           ASN         :
    Disk Usage : 1.8 GiB (5% Used)                  ISP         :
    Mem        : 3.7 GiB                            IPv4        : ✔ Enabled
    Mem Usage  : 0.3 GiB (9% Used)                  IPv6        : ✔ Enabled
    Disk Performance Check (ext4 on /dev/sda1) (R: Read, W: Write, T: Total)
    | Size | Read        | Write       | Total       |       IOPS (R,W,T)       |
    | 4k   | 145.35 MB/s | 145.73 MB/s | 291.09 MB/s | 37.2k  | 37.3k  | 74.5k  |
    | 64k  | 831.01 MB/s | 835.38 MB/s | 1.62 GB/s   | 13.3k  | 13.4k  | 26.7k  |
    | 512k | 840.00 MB/s | 884.63 MB/s | 1.68 GB/s   | 1.7k   | 1.8k   | 3.4k   |
    | 1m   | 851.37 MB/s | 908.07 MB/s | 1.71 GB/s   | 0.9k   | 0.9k   | 1.8k   |
    Network Performance Test (Region: Mixed)
    | Prot. | Provider    | Location        | Send         | Receive      | Latency   |
    | IPv4  | Airstream   | Wisconsin, US   |  246.3 Mb/s  |  886.1 Mb/s  |  119.5 ms |
    |       | Uztelecom   | Tashkent, UZ    |  370.5 Mb/s  |  900.7 Mb/s  |  106.3 ms |
    |       | Novogara    | Amsterdam, NL   |  249.5 Mb/s  |  255.2 Mb/s  |   25.4 ms |
    |       | FiberBy     | Copenhagen, DK  |  214.1 Mb/s  |  408.8 Mb/s  |   31.3 ms |
    | IPv6  | Airstream   | Wisconsin, US   |  451.4 Mb/s  |   42.1 Mb/s  |  121.5 ms |
    |       | Uztelecom   | Tashkent, UZ    |  341.7 Mb/s  |  984.6 Mb/s  |  106.3 ms |
    |       | Novogara    | Amsterdam, NL   |  858.4 Mb/s  |  320.1 Mb/s  |   32.6 ms |
    |       | FiberBy     | Copenhagen, DK  |  669.8 Mb/s  |  137.7 Mb/s  |   35.0 ms |
    | Geekbench 6.1.0 for Linux AVX2                |
    | Single Core        | 887                      |
    | Multi Core         | 896                      |
    | https://browser.geekbench.com/v6/cpu/4230972  |
    | Benchy time spent  | 17 Minutes 18 Seconds    |
  • @c1vhosting said:
    ROME VPS
    No :(
    Sad.
    TY
  • My Italian is rusty but... "creaiamo" sounds like a misspelling?
    404 Error: Signature Not Found
    yes
