Help required (windows server2012)
AK_KWHAK_KWH Hosting ProviderOG
Hi,
i had to migrate one of my windows server active user list to another server i m not familiar with windows if anyone had experience so please share it how to move users between two server only users i want move not the data
  • Never had to do this myself yet, but I remember saving this to my bookmarks: Active Directory Migration Tool (ADMT)
    And maybe this guide goes along with it: http://www.rebeladmin.com/2019/01/step-step-guide-migrate-active-directory-2012-r2-active-directory-2019-powershell-guide/
  • DewlanceDewlance Hosting ProviderOG
    You can install "Backup and Restore" tool from Feature Manager.
    Then create backup of users with custom option and exclude data like desktop, etc.
    Dewlance - Affordable Shared/Reseller/Master Reseller Hosting
    WHMCS Addon - DemoTiger Video KB - Tutorial Videos for Hosting Providers.
  • mikhomikho AdministratorOG
    @AK_KWH said:
    Hi,
    Is the server joined to a domain or stand-alone?
    What exactly do you want to move? Only the username/password?
    If you copy/grab the profile folders you will get settings for installed applications and such, things that are installed in the user profile.
    Since you say you don’t want to move data.
    @mikho said:
    @AK_KWH said:
    Hi,
    Its was used for only desktop uploading downloading nothing else it had i want to switch the provider bcz current one had a few network issue so i want to go with another one what i want i just want the username/passwords so i dnt need to be setup every single user again manually i dont need any other thing to be sifted
    it will move all data too :) i dont want the data i just want the username/password only
    To my knowledge (as I've never tried it) you can't copy the password between stand-alone servers. (unless using option 1 below)
    It would be easier if both were AD-joined but that is another cost (separate AD-server needed).
    1. You can sniff the hash (requires the user to change their password once on the old server) - not recommended.
    2. You can copy the usernames and require the users to change their passwords at first login (you set a password for each account)
    You also need to copy all groups from the first server and create them on the second server.
    On the old server, I would use Powershell commands to get the lists of users/groups/membership into a csv file(s)
    • Get-LocalUser
    • Get-LocalGroup
    • Get-LocalGroupMember
    and then, on the new server use the following commands with data from the csv file(s):
    • Create-LocalUser
    • Create-LocalGroup
    • Add-LocalGroupMember
    Create random passwords and assign to each LocalUser and send them to the users, and password change on the first login.
    Thanked by (2)AK_KWH Dewlance
    Thanks for the solution @mikho <3
    Thanked by (1)mikho
