mrvm.net openvpn tun
Tried setting up openvpn on the US and Bulgaria node and tun is not available, is it available at only certain locations or there is some configuration to enable tun that I missed out?
    edited April 2020
    @mikho will be the only one to answer that.
    Virtualizor is like trying to find a piece of hay in a hay stack, probably just a tick box for those locations would be my guess.
  • mikhomikho AdministratorOG
    Check the box under ”VPS Configuration”.
    1. Stop the VPS from the control panel, not from inside the VPS.
    2. start VPS.
    3. Good to go.
  • Got it working, thanks @mikho :D
    Thanked by (1)mikho
