Data to S3 - google or s3 which one is cheapest?
Looking for bash script/sotfware or anything which can transfer data from Google Drive (2TB) to S3 storage. In short, with automation.
Another question: Google Drive (2TB, $10/month) or AWS-S3 (2TB) (which one is cheapest)
Please recommend and give your suggestions.
Rclone?
https://forum.rclone.org/t/make-a-copy-of-folder-on-google-drive-using-rclone/11259
I am using rclone since years and was not sure if its able to do or not but thanks for reminding.
Correct link is this https://forum.rclone.org/t/copy-files-from-google-drive-to-s3/8711
Update: Transfer looks good. Rclone is
Wasabi is the cheapest S3 compatible storage provider. Just $6 per TB/month. No egress costs.
https://wasabi.com/cloud-storage-pricing/#three-info
Agree on Wasabi. Use it daily, using restic on all of my servers.
https://restic.net/
Just use gsuite for business?
Note that wasabi has a 90 day retention policy on data. So any data written to them will have a minimum charge of 90 days even if it's deleted. After 90 days any data removed won't be charged. This isn't a big deal for backup but should be remembered regardless of use case also the egress is basically a monthly limit on the amount your storing. So if it's 1tb it's 1tb of egress a month before they "warn" you. I don't know how much of a hard limit that egress is but it's now noted on their site. They are still worth consideration though. Honestly a good backup use case would be both wasabi and another location/company as a two company two data Center redundancy.
Didn't know, good addition! Thanks
Works a lot cheaper than B2
Squats are the new Push-ups
Again though you have to remember the 90 day billing cycle on new data which B2 doesn't have. I believe they bill for day on the day.
https://wasabi.com/cloud-storage-pricing/pricing-faqs/#:~:text=With Wasabi minimum storage retention,using Wasabi's RCS pricing model
Also please be aware Wasabi's uptime record isn't good compared to B2, S3 or Google.
Wasabi was a mandatory dependency of our provisioning system but we moved to self-hosted minio last month to get rid of frequent performance issues and downtime :-(
And Reliable high-performance virtual server | Ashburn, New York, Seattle, San Jose, Hong Kong, Tokyo, Singapore, São Paulo, Johannesburg
Scaleway offer 75GB free S3 storage and 75GB outgoing traffic.
Their datacenters are located in Amsterdam and Paris.
https://www.scaleway.com/en/object-storage
Interesting. Which data Center location were you using? Also how's minio been treating you? Did you use a cluster in one location or cluster over multiple locations? Or single system stored locally?
I have some atom nucs and tempted to try out a 12tb raid 1 setup now that 12tb drives are actually affordable
was us-east-1 then us-east-2 after the two-weeks-long outage.
We've moved to a 3-node cluster in Reston over our own VM platform. So it's a single location.
Nice! How's performance and reliability been with minio? Do you have all the same size drives or mix and match?
