Happy Independence Day 2020!!
mikhomikho AdministratorOG
edited July 2020 in Offers
HAPPY 4th all Americans !!
I have a special deal for all of you (and the rest of the world as well).
Shared IPv4 with 20 Forwarded Ports + 1 SSH Port,
/112 IPv6 Subnet
Control Panel including Reverse Proxy management, managed from the regular Client Area.
Disk: 5gb
Ram: 256mb
Transfer: 500gb (then capped @ 10mbit/s)
Virt: Openvz7
7 US Locations:
  • New York
  • Miami
  • Las Vegas
  • Los Angeles
  • Lenoir
  • Berkeley Springs
  • Seattle
Only $3 / each!
On a scale from 21 to FREEDOM, where are you?
Order Link: https://clients.mrvm.net/cart.php?a=add&bid=20
Common uses are:
  • Teamspeak Servers
  • VPN Servers
  • Proxy Servers
  • Web Servers
  • Distributed database master<>master/slave setups
  • Scrapers
  • Cheap HA using Cloudflare and round-robin DNS
  • IRC clients (IPv6 only)Common uses are:
Terms tl:dr
No tor.
No open proxies.
No torrenting.
TUN/TAP available via the control panel
FUSE Support
NFS Support
Full Netfilter support (the usual crap missing from OpenVZ containers)
CPU is fair share not dedicated it is covered in the first paragraph of the terms, read this if nothing else.
No click bots/auto browser schemes.
Support is limited to VPS Issues only. Having problems with an application? Post your questions on this forum.
As usual with WHMCS bundles, you set up the first location, then click continue and set up the next location. Keep going until all locations have been set up.
*Orders will be provisioned manually within 48 hours.
  • master<>master/slave setups
    This is not OK. Change to “leader/follower” or “primary/secondary”.
    My girlfriend tried this when she got out the whips and black leather. "Come here, secondary" doesn't have quite the same ring to it.
    Thanked by (1)vimalware
    Congratulations on completing your leader degree in Computer Science!
    Doesn't quite have the same ring to it.
  • I like to live dangerously.
    My Db master don't need no... Data assistants...
  • Thanks mikho for the offer. It was nice for you to do it.
