Remote Development Environment
I’m trying to setup Grav, so my wife can create a blog to share stuff with our extended family.
She is tech savvy but not a developer. She’s currently using a Mac.
My idea is to setup Grav in a VM on our home server as a development environment, push the changes to a private Github repo and pull the changes to a VPS once she is happy with the changes.
I know Grav can be edited via the Admin portal but I think eventually she may need to edit files directly.
I though about some options:
VS Code + SSH
Atom + a remote editor plugin + Github plugin
map remote folder via SSHFS, VS Code/Atom
Any suggestions and experience from a similar setup?
    edited July 2020
    Use runcloud, it has a grav auto-installer, free backups that can be used as snapshots and connects to github https://lowendspirit.com/the-nuts-and-bolts really is super simple.
    Thanked by (1)beagle
  • havochavoc OGContent Writer
    I'd suggest going straight for WYSIWYG editor approach - whether that's wordpress or Grav or whatever.
    Family doesn't cope well with concepts like SSH etc in my experience, but maybe yours is different.
  • beaglebeagle OG
    edited July 2020
    Your post was the inspiration to go with Grav, but would you suggest to edit directly on the server instead of pushing changes from a development environment?
    Do you ever need to edit the files directly? Or can you do everything via admin portal?
  • code-server maybe? Very easy to install and use.
    You can use their install script or LinuxServer's docker image.
    edited July 2020
    I just have a separate staging site https://staging.lowendspirit.com/ for core changes however the admin side of grav just ticks all the boxes so I don't really find I need to worry about pushing to a dev environment and the restore function on runcloud takes literally 10 seconds to restore the entire site, at the end of the day its just a bunch of markup files :)
    I just edit directly on the server, if I mess up it takes seconds to correct and I have hourly backups in runcloud anyway which I can mess with at a file-level if needed.
  • I don't have expirience with grav, but you should be able to just install apache and php on her mac, If it works IMO that would be perfect development environment.
    Is most of this functionality available on the free plan? I remember you said you used the free plan to start with but I couldn't find any information on their site about what features are available.
    hmm, not sure, I switched up a while back so genuinely don't remember.
