What are you using for incremental backups?
I am using centminmod and i am looking for some way to do incremental backups for a php script website. To do moment i have been using only wordpress so i was using some back up plugins but now i would need another solution. What are you using for incremental backups?
Dentistry is my passion
    Many people probably are using JetBackup.
    I've also heard of some people using "rdiff".
    Thanked by (1)Chievo
  • JetBackup for cPanel and BackupPC for everything else.
    Thanked by (2)Chievo Ympker
    Thanks @Ympker ! I am going to check the compatibility of centminmod with it.
    Thanks @imok ! I have seen that backuppc is using apache and centminmod is Nginx :(
  • havochavoc OGContent Writer
    Borgbackup is next on my list of things to investigate.
    Thanks @havoc ! I have checked and borg is paid option only available for premium members for centminmod. I have not tried to use it( only borg ) so i do not know if it is better than rsync. Well rsync is free and borg it is a paid option for centminmod
    @Chievo said: I have checked and borg is paid option only
    Its free open source software so not sure what you're looking at there
    https://github.com/borgbackup
    Yes borg is open source but i am using centminmod and the option for borg is an addon only available for premium users ( so it is "paid" option).
    You should still be able to setup borg manually, without the addon. It's still a regular linux server.
    Thanked by (2)Chievo vimalware
    OK in that case i must try to install it manually thanks for the clarification :)
    edited July 2020
    You're welcome :)
    I don't think there is any way Centminmod would be able to prevent you from using Borg Backup afaik. It's like if you have a WordPress plugin and certain features are only available for premium. If you code a plugin which covers the missing features yourself, or find another plugin/solution (in this case Borg) to do the job, it'll still work.
  • I really, really enjoy Duplicacy. Command line is free for personal use.
    Thanked by (2)Chievo jaden
    You mean
    https://www.duplicati.com/
  • @vyas said:
    You mean
    I guess he means https://duplicacy.com if i am not wrong
    @vyas said:
    You mean
    I've used this & was overall happy. Heard horror stories about restoring big backups (it taking weeks) though hence me wanting to look at borg next
  • @vyas said:
    You mean
    @Chievo said:
    @vyas said:
    You mean
    Yup. Duplicacy. Works well, encrypted, fast, uses snapshots when available.
    Thanked by (2)vyas Ympker
  • Learnt something new
    Thanks
    Thanked by (2)Ympker sgheghele
  • tetechtetech OG
    edited July 2020
    @havoc said:
    @vyas said:
    You mean
    Borg is good. Very happy with it. Quite fast for large numbers of small files.
    For VMs, for a few years I've been using a rsync script, and then creating a hardlinked copy each day. This means linux takes care of all the incremental stuff.
    But generally these days, I'm taking an incremental btrfs snapshot of the entire container. I'm sending all logs to a centralized rsyslog server, so the snapshots tend to be small. Might not help the OP with centminmod though.
  • I'm also using borg to push backups over from everywhere.
    It has plenty of useful features.
    There is also https://restic.net/ but haven't tested it yet.
  • I'm using UpdraftPlus for my WordPress sites, and Veeam Backup & Replication for my servers. Works great, and deploying the Veeam agent to each server is as simple as pasting an IP address in the B&R console :)
    Thanked by (2)Ympker vyas
    What sort of servers (i.e. RAM, disk)? I found Veeam to be heavy on the resources, but could be I have lower-end stuff.
  • @tetech said: What sort of servers (i.e. RAM, disk)? I found Veeam to be heavy on the resources, but could be I have lower-end stuff.
    The Veeam agent is very light in my experience. I have installed on my local machine (Ryzen 4500U, 8GB RAM) as well as many of my servers (with RAM ranging from 512M-8GB). Usually the B&R Console shows the bottleneck as my backup target anyways, and I haven't observed high CPU usage on backup source machines while backups are running.
    Interesting. Thanks for sharing the datapoint. From memory (it has been a while) my issue was with de-duplication of some quite large files, and it being very slow when doing a synthetic full backup.
  • I just use Proxmox Backup Server
  • +1 for duplicacy (backing up to Wasabi).
    I also create a daily rclone snapshot to BackBlaze B2 for redundancy.
    Thanked by (1)sgheghele
    Same, in addition to incremental with Duplicacy I have a daily rclone copy to 1fichier :+1: (encrypted 7z).
    Good old 1Fichier :)
    Guess whose recommendation I followed, almost two years ago, to get multiple years of it? :-) I'll keep an eye on Koofr, if they ever discount their 1TB again (maybe for Black Friday).
    I'm using restic, and I must say I really like it. It's lightweight, easy to use, efficient and very scriptable.
    Thanked by (1)tehdartherer
  • vyasvyas OG
    edited July 2020
    Any resources or How Tos for doing this?
    (backup via rclone --> I use pCloud and Duplicacy for b2)
    Thanks in advance
