MaxKVM has Landed in Singapore!
15681011
  • @seriesn said:
    @MaxKVM said:
    @vimalware said:
    Next step : unmetered private networks. ?
    And here I was about to ask what you guys wanted to see next from MaxKVM. Internal private networking is definitely on the roadmap!
    We appreciate any and all feedback. What features/promos would you like to see next?
    Yo. Hmu if you figure out a way to fo this with virtualizor.
    I have the whole thing setup on the network level but VPSs won't talk to each other over local ip, if they are on a different hardware :(
    We use SolusVM my brother. :) It sounds like you might need a VLAN to get those internal IPs to communicate across nodes in the same DC, but not too sure of your network setup.
    Node to node communication works. Virtualizor doesn't allow VM to communicate across different nodes over local IP and have 0 intention of manually fiddling with their configs.
    SolusVM supports internal networking across nodes? Or is it part of solus io?
  • Pliss untag me.
    That's a good question. The only documentation available details how to enable private/internal networking for individual nodes with nothing regarding private network communication between separate nodes. The assumption was that getting this to function as expected (one private network for VMs to communicate between each other on separate nodes in each DC) would take some custom network configuration.. and many migraines..
    @ vimalware said:
    Pliss untag me.
    Never :p
    Thanked by (1)vimalware
  • Many migraines for me, when I attempted to hack out a custom solution last year. End result, without building own panel, it won’t be worth the effort.
    Of course it would be worth the effort! There might even be more than 1 or 2 people who would make use of this feature.. ;)
    We actually do have quite a few with multiple VMs.. and have had a couple of requests for internal private networking. One other feature that has been requested a couple of times is an external/cloud firewall, which will probably involve many, many more migraines. But that might be pretty awesome to get working. B)
    Edge firewall would definitely be an awesome add on :)
  • +1 private network
    Thanked by (1)MaxKVM
  • @MaxKVM said: We just received notice that there was a re-route completed for Indonesia
    I don't remember there was an issue with ID routing? The test is always good;
    tracert lg.sin.maxkvm.net
    Tracing route to lg.sin.maxkvm.net [2402:9e80:8:1::100:1]
    over a maximum of 30 hops:
      1     5 ms     3 ms     3 ms  2404:8000:1004:ccf:da07:b6ff:fe83:7bd4
      2     6 ms     6 ms     5 ms  2404:8000:1:1110::7d
      3     7 ms     7 ms     7 ms  2404:8000:1:7451:99::66
      4    10 ms     6 ms     9 ms  2404:8000:1745:1::50e
      5    18 ms    20 ms    21 ms  2404:8000:1745:1::57a
      6    32 ms    17 ms    17 ms  as22822.singapore.megaport.com [2001:ded::10]
      7    20 ms    17 ms    17 ms  ve5.fr4.sin.ipv6.llnw.net [2402:6800:730:1001::2]
      8    31 ms    52 ms    43 ms  2604:8380:3400:0:107:155:95:253
      9    17 ms    17 ms    17 ms  lg.sin.maxkvm.net [2402:9e80:8:1::100:1]
    Trace complete.
    tracert -4 lg.sin.maxkvm.net
    Tracing route to lg.sin.maxkvm.net [107.155.95.100]
      1     3 ms     2 ms     2 ms  192.168.10.1
      2     8 ms     5 ms     5 ms  10.156.0.1
      3     9 ms     7 ms     6 ms  id-jkt-mid-8.biznetnetworks.com [182.253.99.33]
      4     9 ms    12 ms    11 ms  id-jkt-mid-1.biznetnetworks.com [182.253.99.105]
      5    21 ms    20 ms    20 ms  jkt-gs-7.biznetnetworks.com [182.253.187.26]
      6    18 ms    17 ms    17 ms  as22822.singapore.megaport.com [103.41.12.16]
      7    36 ms    38 ms    29 ms  117.121.248.217
      8    17 ms    16 ms    17 ms  lg.sin.maxkvm.net [107.155.95.100]
    Trace complete.
    Thanked by (2)MaxKVM chocolateshirt
    You're lucky, on my way to my sg MaxKVM service, my connection flies through Singapore, out to Stockholm and France, it seems :)
    And from my sg MaxKVM service I get a detour via India. Definitely racking up the frequent flyer miles :lol:
    Plotting pings on a graph results in this:
    > Trace complete.
    > Trace complete.
    I wish my internet provider have IPv6..
    Oh lord... :o
    That's not good. Is IPv4 taking a worldwide trip to Stockholm and France or IPv6? or both?
    Oh lord... :o
    Did a bit more testing, looks like v6 routes properly and sits around 100ms ping (which is what I expected), so problem has been narrowed down to being v4 only.
  • debaserdebaser OG
    edited August 2020
    Oh lord... :o
    What we really want to see is an mtr/tracert of this scenic route B)
    Oh lord... :o
    :lol: singing "We're all going on a ... summer holiday"
    Tracing the route to 107.155.95.100
     1  HundredGigE0-0-0-8.core2.vdc01.syd.aussiebb.net (180.150.1.186) [MPLS: Label 24084 Exp 0] 99 msec  96 msec  96 msec
     2  be2.core2.nextdc-s1.syd.aussiebb.net (202.142.143.203) [MPLS: Label 24082 Exp 0] 95 msec  96 msec  95 msec
     3  be1.core1.nextdc-s1.syd.aussiebb.net (180.150.1.116) [MPLS: Label 24131 Exp 0] 96 msec  95 msec  96 msec
     4  HundredGigE0-0-0-13.core1.nextdc-p1.per.aussiebb.net (202.142.143.55) [MPLS: Label 24103 Exp 0] 103 msec  94 msec  97 msec
     5  be1.core2.nextdc-p1.per.aussiebb.net (202.142.143.149) [MPLS: Label 24245 Exp 0] 96 msec  94 msec  94 msec
     6  be3.core1.sg1-equinix.sin.aussiebb.net (180.150.2.85) 94 msec  95 msec  95 msec
     7  ae0-207.RT1.EQX.SIN.SG.retn.net (87.245.238.226) 98 msec  97 msec  96 msec
     8  et815-9.RT.IRX.STO.SE.retn.net (87.245.234.200) 268 msec  269 msec
        ae7-9.RT.IRX.STO.SE.retn.net (87.245.232.34) 263 msec
     9  tge13-4.fr4.arn1.llnw.net (87.248.192.206) 263 msec
        87.248.192.32 268 msec
        tge13-4.fr4.arn1.llnw.net (87.248.192.206) 257 msec
     10 lag169.fr4.arn1.llnw.net (68.142.89.218) 285 msec  259 msec
        tge1-4.fr3.fra1.llnw.net (69.28.172.121) 268 msec
     11 tge4-3.fr3.lin1.llnw.net (87.248.220.158) 279 msec
        p1-1.fr4.fra1.llnw.net (178.79.240.10) 268 msec
        tge4-3.fr3.lin1.llnw.net (87.248.220.158) 285 msec
     12 tge1-1.fr4.mrs1.llnw.net (87.248.194.223) 299 msec
        lag36.fr4.lin1.llnw.net (68.142.88.117) 291 msec
        ve5.fr4.lin1.llnw.net (69.28.172.210) 287 msec
     13 lag57.fr4.sin.llnw.net (111.119.23.92) 276 msec  273 msec
     14 107-155-95-253.static.hvvc.us (107.155.95.253) 293 msec
        lag57.fr4.sin.llnw.net (111.119.23.92) 276 msec  276 msec
     15  *
        107-155-95-253.static.hvvc.us (107.155.95.253) 292 msec  *
     16  *  *  *
     17  *  *  *
    Mars.. Hmmm.
    or maybe a French Mistress.
    both are plausible explanations for the detours.
    Thanked by (1)bdl
    Squats are the new Push-ups
  • edited August 2020
    It seems IPv6 is taking a break from vacations and IPv4 is taking its place!
    Actually surprised to hear proper latency for IPv6 since there was no mention of optimization and mtr.sh shows IPv6 still travelling to the US from Anexia Sydney.
    Edit: I take that back. We have a direct route with IPv6 from Anexia Sydney to MaxKVM SG:
    2402:9e80:8:1::100:1 | MTR from Anexia AS42473 in Australia, Sydney
                                                              Loss% Drop   Rcv   Snt  Last  Best   Avg  Wrst StDev Gmean Jttr Javg Jmax Jint
      1.|-- 2a00:11c0:36:900::52                               0.0%    0    10    10   0.4   0.2   2.3  20.1   6.3   0.5  0.1  2.1 19.8 12.8
      2.|-- as6939.nsw.ix.asn.au (2001:7fa:11:4:0:1b1b:0:1)    0.0%    0    10    10   4.8   4.8   6.4   9.6   1.7   6.3  0.0  1.7  4.2 12.2
      3.|-- e0-36.core1.syd3.he.net (2001:470:0:4f2::2)        0.0%    0    10    10  13.0  13.0  14.4  24.0   3.4  14.1  0.1  2.3 10.7 19.7
      4.|-- e0-36.core1.per1.he.net (2001:470:0:4ee::2)        0.0%    0    10    10  92.8  92.5  92.7  93.3   0.3  92.7  0.5  0.2  0.5  1.7
      5.|-- 100ge12-1.core1.sin1.he.net (2001:470:0:4ee::1)    0.0%    0    10    10 109.9  92.1 106.3 114.8   9.9 105.8  0.8  2.9 22.7 20.6
      6.|-- as22822.singapore.megaport.com (2001:ded::10)      0.0%    0    10    10  92.5  92.5  92.5  92.6   0.0  92.5  0.0  0.0  0.1  0.2
      7.|-- ve5.fr4.sin.ipv6.llnw.net (2402:6800:730:1001::2)  0.0%    0    10    10  92.1  91.4  92.7  99.6   2.7  92.7  3.6  2.4  8.2 19.0
      8.|-- 2604:8380:3400:0:107:155:95:253                    0.0%    0    10    10 113.7 100.1 109.6 134.4  10.7 109.2 12.4 10.5 32.6 82.9
      9.|-- lg.sin.maxkvm.net (2402:9e80:8:1::100:1)           0.0%    0    10    10  92.1  92.0  92.1  92.2   0.0  92.1  0.0  0.0  0.1  0.2
    Thanked by (1)bdl
  • @vyas said:
    Mars.. Hmmm.
    or Duck à l'orange instead of Chinese chicken
  • vyasvyas OG
    edited August 2020
    @bdl said:
    @vyas said:
    Mars.. Hmmm.
    @MaxKVM's choice...
    Fragrant... like French Parfum
  • @vyas said:
    @bdl said:
    @vyas said:
    Mars.. Hmmm.
    @MaxKVM's choice...
    You heard it here, folks. Hostloc is completely wrong and we are unquestionably fragrant. :lol:
  • @vyas said:
    Mars.. Hmmm.
    What it looks like to me is that STO is a faulty rDNS, that router seems to be in Frankfurt.
    However, what’s really happening here is that @bdl ’s ISP seems to buy transit at RETN, they peer with LLNW so they scream ‘we have the fastest route, it’s almost direct’ whereas with other carriers there’d be a transit provider in the middle.
    Only problem is that RETN and LLNW peer with eachother in Frankfurt and not Singapore.
    I’d think that this is something that has to be changed at the end of your ISP. There’s only so much you can do on the other end.
    Thanked by (3)MaxKVM Abdullah bdl
  • My traceroute [v0.93]
    Serv.tub.co (2402:9e) 2020-08-27T18:17:21+0000
    Keys: Help Display mode Restart statistics Order of fields quit Packets Pings
    Host Loss% Snt Last Avg Best Wrst StDev
    1. 2402:9e8 0.0% 107 2.0 7.5 0.4 81.3 10.9
    2. 2604:8380:3400:0:107:155 0.0% 107 0.2 0.3 0.2 3.9 0.4
    3. limelight.singapore2.sin 0.0% 107 0.3 0.7 0.3 26.5 2.6
    4. 2403:e800:e804:9::1 58.9% 107 77.0 75.8 75.5 78.8 0.7
    5. 2403:e800:508:100::e6 0.0% 107 135.9 128.6 107.5 159.3 8.8
    6. 2400:5200:1800:69::2 0.0% 107 135.8 132.5 112.1 145.4 7.7
    7. 2400:5200:1800:69::1 36.8% 107 144.2 140.2 118.7 149.1 6.7
    8. fd00:abcd:abcd:128::1 0.0% 106 139.1 132.7 112.9 144.2 7.5
    9. 2402:3a80:1831:fd04:0:4: 0.0% 106 140.0 132.7 113.2 144.2 7.8
    10. 2402:3a80:1831:fd04:7904 3.8% 106 197.3 188.5 146.1 237.4 14.5
  • @deepak_leb, formating MTR result with <pre> would be great
    Thanked by (1)deepak_leb
  • Is someone able to check and confirm if the IP range is detected as Singapore?
    What do you mean by that, sir? The geoIP location?
  • @debaser said:
    @vyas said:
    Mars.. Hmmm.
    Thankyou @debaser . That does correlate with what I'm experiencing with other sites which use other ISPs/connectivity, they have no problem achieving 100ms taking other routes with providers that peer much closer to Singapore.
    It seems there is still an opportunity to optimise the route in the opposite direction from my .sg MaxKVM service, the mtr doesn't show much however that fourth hop is where it seems to go via India...
     1. 10.22.22.254                                    0.0% 30226    0.1   0.0   0.0   0.3   0.0
     2. 107.155.95.97                                   0.0% 30226   22.4  10.3   0.9 168.3  16.1
     3. 117.121.248.216                                 0.0% 30226    1.2   0.3   0.2 326.9  13.9
     4. 125.19.200.65                                   0.0% 30225  172.3 172.1 167.2 300.1   7.6
     5. (waiting for reply)
     6. HundredGigE0-0-0-8.core2.vdc01.syd.aussiebb.ne  0.0% 30225  273.8 272.8 269.1 316.0   0.8
    (yes, quite a few packets have been sent, I accidentally left this going all night :smiley: )
    Indeed good sir.
  • @bdl said:
    @debaser said:
    @vyas said:
    Mars.. Hmmm.
    Problem is that it boils down to the interconnect between a carrier of your ISP and a carrier of Hivelocity. The most drastic improvement would come from a manual change at your ISP. They could (for insance) route it through NTT. But access providers are usually not open for this kind of shenanigans.
    It's not India though. It's (dramatic sound) Los Angeles. So yeah, Hivelocity could make some changes though (not that it would do too much about the high latency).
    Hivelocity is apparently trying to save some money over bandwith cost, in order to deliver a server with the same specs for the same price as in Europe and the US. That's understandable, but gives these kinds of problems due to the TIER-2 and TIER-3 networks they're using for upstream.
    Seeing the routes in this thread makes me very happy to live in Western Europe. Almost everything just goes from point A to B here. And when it doesn't its routes that go (for instance) not directly from Amsterdam to New York, but from Amsterdam to Paris to Washington DC to New York. Or routes to Scandinavia that travel through Frankfurt. That kind of detours is in the early double digits of extra latency. Hundreds of kilometres, not thousands.
    Thanked by (1)bdl
    You wouldn't happen to have a spare room I could borrow? :lol:
    I do, but that's the room without internet so...
    I had an Ozzie colleague who moved back to Australia after some years in The Netherlands. I asked him what he was going to miss the most (except from us of course) and he answered: 'affordable internet and good speeds no matter what'. So yeah.
    Thanked by (1)bdl
