Filegator - Open Source/ Self Hosted File Management
vyasvyas OG
edited September 2020 in General
Looks interesting, I liked the clean interface. Played around with the demo (which of course does not allow uploading/ editing/deleting files) but liked it enough to give it a try on one of the idlers.
https://filegator.io/
Docs & How To Install
https://docs.filegator.io/install.html
Filegator file management application
Squats are the new Push-ups
Thanked by (3)ehab allendiggity Abdullah
  • Been using NC.
    Never looked back
  • @deepak_leb said:
    Been using NC.
    what is NC
  • @ehab said:
    @deepak_leb said:
    Been using NC.
    what is NC
    NextCloud.
    Thanked by (1)ehab
  • Although FileGator looks shiny and nice, I wonder what its main use case is. After all, we have ftp.
    Also, since version 7 is "completely rewritten from scratch" and dates from only last year, I'd be a bit cautious before installing it on a production system. By comparison, Nextcloud is time- and deployment-tested.
    Just my two cents -- I don't mean to spoil the fun :)
    Thanked by (1)vyas
    Certainly! Definitely not for a production site.
  • It is nice - thanks. Comments regarding production use noted.
  • vyasvyas OG
    Congratulations on your 347 thanks. Er... just bumped it to 348
    Thanked by (1)angstrom
  • It's a good replacement for FTP, if you prefer to had ability to preview some files use H5ai.
    Nextcloud too bloatware
  • Nextcloud is really good specially with integration to only office
  • Nextcloud is in a different comparison class than FileGator, so there wouldn't be much point in directly comparing the two. Clearly, if all that you want/need is a web-based file manager, then Nextcloud would be overkill, but the question (which I asked above) is what the main intended use of FileGator is. If FileGator is a replacement for (s)ftp, then it seems to me to be overkill (and too fresh out of the oven to trust on a production machine).
    As I also said, FileGator looks shiny and nice, and if you're inclined to try to make everything web-based, then it may be worth a look, but I'd also be a little cautious ...
    Thanked by (1)vimalware
  • I'd put it behind a vpn.
  • Thanks for sharing. Simple and clean interface. It’s exactly what I’ve been looking for.
    Filegator has been around a long time, originally it was sold on CodeCanyon.
    Used it a lot in the past (before the rewrite) and it was always solid, used it as a way to share an FTP folder on the web with user restrictions, will definitely check out the new version of it!
    Syuh - sftp, rsync & rclone accessible storage from 50GB to TBs.
