AMD EPYC NAT VPS| 256MB - 2GB | Singapore ?? Netherlands ?? New York ??
Hi,
What is a NAT VPS?
Network Address Translation (NAT) is the process where a network device, usually a firewall, assigns a public address to a computer (or group of computers) inside a private network.
So a VPS that’s utilizing this kind of technology is shortly understand-able as a VPS with shared IPv4.
It comes with a dedicated IPv6 subnet.
In low end vps world, the main purpose of NATted VPS is also to make the price as low as possible.
Most popular OS choices like Ubuntu, Debian and CentOS can be installed from the control panel.
Shortly it’s just like any common VPS, but it comes with Shared IPv4, not dedicated.
All plans come with /112 IPv6 Subnet, NAT IPv4 with 20 usable ports + 1 SSH port, Domain Forwarding(host on IPv4 port 80/443)
VPS - NAT256
4GB NVMe SSD Disk
256MB DDR4 ECC RAM
1 vCPU EPYC 7302P (Fair Use)
500GB transfer @ 1Gbit; then unlimited at reduced speed£5.5 £4.5 / year use coupon SRVRHUNT2020
Order in Singapore | Order in Netherlands | Order in New York
VPS - NAT512
7GB NVMe SSD Disk
512MB DDR4 ECC RAM
1 vCPU EPYC 7302P @ 3.0Ghz (Fair Use)
750GB transfer @ 1Gbit; then unlimited at reduced speed£8.7 / year; no coupon required.
VPS - NAT1G
15GB NVMe SSD Disk
1G DDR4 ECC RAM
1.5TB transfer @ 1Gbit; then unlimited at reduced speed£15.8 / year; no coupon required.
VPS - NAT2G
30GB NVMe SSD Disk
2G DDR4 ECC RAM
2 x vCPU EPYC 7302P @ 3.0Ghz (Fair Use)
2.5TB transfer @ 1Gbit; then unlimited at reduced speed£28.5 / year; no coupon required.
What can you use this kind VPS? Here it is few examples of what you can do with it:
- Host a full-fledged website (w any CMS like Wordpress, Ghost etc) on port 80/443
- VPN - Most protocols including OpenVPN & Wireguard can be used.
- Proxy (private, protected)
- IRC client/server (IPv6)
- VoiP apps like Teamspeak, Mumble etc.
- Anything you want with native IPv6
- A simple remote terminal with root access, testing scripts & other stuff.
- A light usage remote desktop.
- Distributed database, Web Scrapers etc.
- Many more possibilities....may ask in this thread.
Looking Glasses
New York ?? - http://nyc.lg.webhorizon.in
Amsterdam ?? - http://ams.lg.webhorizon.in
Singapore ?? - http://sgp.lg.webhorizon.in
Uptime Reports: https://status.webhorizon.in
Payment Methods:-
- PayPal Payments
- Cards via Stripe Payments
- BTC payments
- RazorPay (INR Payments)
If you have any questions or doubts, please PM or post here.
Thanks for reading & regards,
Abdullah
Promo code doesn't seem to work on the 1st plan. Just displays a red crossed circle when I click redeem.
Fixed it, please try now.
https://webhorizon.net
Restocked 256mb in SG....b.u.m.p.
I can't seem to find whether this is openvz/kvm?
Says NAT which is what it is
Squats are the new Push-ups
It is OVZ 7 sir.
@Abdullah You mentioned in another thread that you solved the problem with giving out public IPv6 addresses to VPN clients? Does that apply to this NAT VPS?
Yes, it was allocating public IPv6 address to NAT VM's. Same case was that it worked fine after some pings & traceroute from NAT container, but will not work otherwise.
disabling ebtables fixed the issue for me.
Thanks, signing up for the NAT256 account.
