?? ** FLASH SALE ** 8GB RAM, 4CPU, 160 GB SSD, KVM - 48€/year
gleertgleert Hosting Provider
  • 4 CPU Core (EPYC)
  • 8GB RAM
  • 160GB SSD
  • 5TB Traffic
  • 1Gbps port speed
  • 1 IPv4
  • /64 IPv6
  • Quantity: 10
  • €48/yr (+VAT if applicable)
  • Promo code: EJ5GP3SAO2
  • Order link: https://clients.naranja.tech/cart.php?a=add&pid=4
Our VPSes (ask for a recurring coupon code) Mailchannels low volume plans
«134
  • Can I upgrade my existing plan to this one, @gleert?
  • gleert is really making us go hmmmmm
  • Not bad at all - Just need to find a use for it now :)
    Processor : AMD EPYC 7302 16-Core Processor
    CPU cores : 4 @ 2999.998 MHz
    AES-NI : ✔ Enabled
    VM-x/AMD-V : ❌ Disabled
    RAM : 7.8 GiB
    Swap : 1023.0 MiB
    Disk : 156.5 GiB
    Read | 219.53 MB/s (54.8k) | 1.05 GB/s (16.4k)
    Write | 220.11 MB/s (55.0k) | 1.06 GB/s (16.5k)
    Total | 439.65 MB/s (109.9k) | 2.11 GB/s (33.0k)
    Read | 1.21 GB/s (2.3k) | 1.31 GB/s (1.2k)
    Write | 1.28 GB/s (2.5k) | 1.40 GB/s (1.3k)
    Total | 2.50 GB/s (4.8k) | 2.72 GB/s (2.6k)
    Clouvider | London, UK (10G) | 904 Mbits/sec | 918 Mbits/sec
    Online.net | Paris, FR (10G) | 881 Mbits/sec | 899 Mbits/sec
    WorldStream | The Netherlands (10G) | 907 Mbits/sec | 939 Mbits/sec
    Biznet | Jakarta, Indonesia (1G) | 689 Mbits/sec | 192 Mbits/sec
    Clouvider | NYC, NY, US (10G) | 727 Mbits/sec | 212 Mbits/sec
    Velocity Online | Tallahassee, FL, US (10G) | 687 Mbits/sec | 329 Mbits/sec
    Clouvider | Los Angeles, CA, US (10G) | 594 Mbits/sec | 68.0 Mbits/sec
    Iveloz Telecom | Sao Paulo, BR (2G) | 708 Mbits/sec | 160 Mbits/sec
    Clouvider | London, UK (10G) | 872 Mbits/sec | 912 Mbits/sec
    Online.net | Paris, FR (10G) | 861 Mbits/sec | 909 Mbits/sec
    WorldStream | The Netherlands (10G) | 890 Mbits/sec | 926 Mbits/sec
    Clouvider | NYC, NY, US (10G) | 685 Mbits/sec | 299 Mbits/sec
    Clouvider | Los Angeles, CA, US (10G) | 604 Mbits/sec | 81.4 Mbits/sec
    Geekbench 5 Benchmark Test:
    Test | Value
    Single Core | 963
    Multi Core | 3364
    Full Test | https://browser.geekbench.com/v5/cpu/5545814
    Thanked by (2)ehab gleert
  • gleertgleert Hosting Provider
    I am sorry, can't do that with a flash sale...
  • @gleert - Is there an option for additional bandwidth? if needed.
  • got one ,thanks!
    Thanked by (1)gleert
    hmmmmmmmmmmm
  • @cybertech said:
    hmmmmmmmmmmm
    Any bench?
    Thanked by (1)cybertech
    How much do you need?
  • Perfect for my small (private) Minecraft community... might have to.
    Note: Your signature might be 3 lines too long
    Thanked by (1)mikewazar
  • Got one too. Thanks @gleert .
  • Hmm, very tempting..
  • @gleert
    Thanks for the offer and the benchmark.
    “Any bench?” Is a joke between @cybertech and I but your link does help
    Thanked by (2)cybertech gleert
  • We all love bench XD
  • @gleert said:
    • 4 CPU Core (EPYC)
    • 8GB RAM
    • 160GB SSD
    • 5TB Traffic
    • 1Gbps port speed
    • 1 IPv4
    • /64 IPv6
    • Quantity: 10
    Can you advise what's cpu usage policy? Still tempted if it is not sold out!
  • @localhost said:
    @gleert said:
    • 4 CPU Core (EPYC)
    • 8GB RAM
    • 160GB SSD
    • 5TB Traffic
    • 1Gbps port speed
    • 1 IPv4
    • /64 IPv6
    • Quantity: 10
    as per their AUP
    Client agrees not to run any processes on his or her VPS which use the equivalent of 50% or more of all available CPU capacity for an extended period of time. As an example, a VPS with four (4) cores assigned may not use more then two (2) full CPU cores for an extended period of time. An exception on this are VPSes with one (1) CPU core assigned – these may use all available CPU capacity. An extended period of time will generally mean two (2) hours, but will depend upon the CPU load and level of impact on other clients sharing the physical server. Disruptive CPU usage may result in a reboot, shutdown, and/or suspension of the VPS regardless of the time lapse involved.
    not exactly straight but with their powerful cpu, it looks good.
    Thanked by (2)localhost gleert
    edited December 2020
    @forces said:
    @localhost said:
    @gleert said:
    • 4 CPU Core (EPYC)
    • 8GB RAM
    • 160GB SSD
    • 5TB Traffic
    • 1Gbps port speed
    • 1 IPv4
    • /64 IPv6
    • Quantity: 10
    as per their AUP
    it looks like 50% allowed, which is very good. would certainly haven gotten one if not for too many idlers.
    good for Plex!
  • @cybertech said:
    @forces said:
    @localhost said:
    @gleert said:
    • 4 CPU Core (EPYC)
    • 8GB RAM
    • 160GB SSD
    • 5TB Traffic
    • 1Gbps port speed
    • 1 IPv4
    • /64 IPv6
    • Quantity: 10
    as per their AUP
    good for Plex!
    Actually, their aup allowed a lot of things...including legal torrenting
    And they are ddos protected...
  • @forces said:
    @cybertech said:
    @forces said:
    @localhost said:
    @gleert said:
    • 4 CPU Core (EPYC)
    • 8GB RAM
    • 160GB SSD
    • 5TB Traffic
    • 1Gbps port speed
    • 1 IPv4
    • /64 IPv6
    • Quantity: 10
    as per their AUP
    good for Plex!
    It's not ddos protected AFAIK. Where did you read that?
  • @Freek said:
    @forces said:
    @cybertech said:
    @forces said:
    @localhost said:
    @gleert said:
    • 4 CPU Core (EPYC)
    • 8GB RAM
    • 160GB SSD
    • 5TB Traffic
    • 1Gbps port speed
    • 1 IPv4
    • /64 IPv6
    • Quantity: 10
    as per their AUP
    good for Plex!
    Their AUP
    Network Connectivity
    Naranjatech can absorb and tolerate occasional DDoS attacks, but customer’s who are targeted with frequent and/or disruptive attacks can be suspended or terminated upon review.
    Customer’s may not use our network and services to send DDoS attacks or other kind of floods, any kind of abusive network usage may result in suspension and/or termination.
    ~8TB
    @OsirisBlack said:
    ~8TB
    Please open a ticket and we will upgrade it for free
  • @gleert said:
    @OsirisBlack said:
    ~8TB
    Perfect - Thanks.
  • @OsirisBlack said:
    ~8TB
    Just curious what do you do with those 8TB.
    Are you running a streaming site?
    I never reach 1 TB all this time.
    @Fritz said:
    @OsirisBlack said:
    ~8TB
    "Linux iso" box
    Thanked by (1)Janevski
  • @cybertech said:
    @Fritz said:
    @OsirisBlack said:
    ~8TB
    "Linux iso" box
    Japan Adult ISO B)
    Thanked by (3)cybertech Ganonk Janevski
  • @Fritz said:
    @OsirisBlack said:
    ~8TB
    Will be using the Box for -
    Wireguard - This will also be attached to my Unraid server - so file movements can be large.
    ZNC Bouncer
    Back up for my SABnzbd - so also rclone to upload my files from this.
    No Linux ISO's - I have a dedi at Nforce for that ;) (160GB is no where near what I would need - were talking TB's here)
    @sonic said:
    @cybertech said:
    @Fritz said:
    @OsirisBlack said:
    ~8TB
    "Linux iso" box
    Japan Adult ISO B)
    yamate!
