Need your opinion
Hi All,
I need to know your recommendation, I am now using OpenVZ VPS with cPanel control panel. I am now planning to use R1Soft for my clients which is not supported by OpenVZ. So, I am planning to migrate it to Xen Servers.
Is this a good move/decision?
  • Xen now feels like an extinct hypervisor. I suggest using KVM.
    KVM best.
    Move to KVM, it has significantly wider support and you will have many more options.
    If you do decide to go with Xen anyway please make sure it is at least Xen HVM not Xen PV.
  • vyasvyas OG
    edited January 2021
    The Xen Master has spoken
    (See comment above this one)
  • edited January 2021
    Enjoy the bugs and regressions in R1Soft CDP. (I battled with developers for months, before deciding it wasn't worth the effort.) :#
