Proxmox question
havochavoc OGContent Writer
Hi gents
If I'm running proxmox on a VPS with one external IP, should I be going for a Routed or Masquerading NAT config?
https://pve.proxmox.com/wiki/Network_Configuration#_routed_configuration
https://pve.proxmox.com/wiki/Network_Configuration#_masquerading_nat_with_tt_span_class_monospaced_iptables_span_tt
Bit confused as to what routed config means by the additional IP block
you have a public IP (assume 198.51.100.5 for this example), and an additional IP block for your VMs (203.0.113.16/29)
I need some sort of port forwarding mechanism, so can't just be outgoing
Thanks
  • In this circumstance you would go for a masquerading setup since you need to follow proper IANA rules and use a internal IPv4 range behind your NAT (similar to your network at home) running on the Proxmox server itself. The example they give is perfectly fine to copy and paste into your config. You can then statically assign IPs to your VMs, or if you wanted to take it a step further, install dnsmasq and have it only hand out addresses to your VMs, changing the binding appropriately.
    Masquerading also allows for port forwarding in this scenario. I got this just by doing a bit of searching around:
    https://www.digitalocean.com/community/tutorials/how-to-forward-ports-through-a-linux-gateway-with-iptables
    Here's an example that forwards port 80:
    sudo iptables -A FORWARD -i eth0 -o eth1 -p tcp --syn --dport 80 -m conntrack --ctstate NEW -j ACCEPT
    Hopefully this is enough to get you started. iptables syntax can be very verbose and overwhelming but thankfully once you see what each flag does, it is quite human readable.
    Best of luck!
    Thanked by (1)havoc
  • havochavoc OGContent Writer
    Best of luck!
    Thanks Camo. I shall give that a shot tonight after work.
    Must admit iptables is still a mystery to me
    Thanked by (1)CamoYoshi
  • edited February 2021
    @havoc said: Bit confused as to what routed config means by the additional IP block
    this is actually the answer to your question. literally.
    no additional (external) IPs, no routed config.
    Join the club :)
    Thanked by (1)mikewazar
  • AsimAsim OGServices Provider
    I always add a RouterOS VM and configure everything via that. Serves perfectly on 1GB disk and 512MB ram
    OK finally got port forwarding to work...took a bit of trial & error
    auto lo
    iface lo inet loopback
    auto eth0
    iface eth0 inet static
            address 148.XXX.XXX.XX2/24
    gateway 148.XXX.XXX.XX2
    #Till here is defaults per proxmox
    auto vmbr0
    iface vmbr0 inet static
            address 10.10.10.1/24
            bridge-ports none
            bridge-stp off
            bridge-fd 0
            post-up   echo 1 > /proc/sys/net/ipv4/ip_forward
            post-up   iptables -t nat -A POSTROUTING -s '10.10.10.0/24' -o eth0 -j MASQUERADE
            post-down iptables -t nat -D POSTROUTING -s '10.10.10.0/24' -o eth0 -j MASQUERADE
    #Portforward port 2222 external to 22 on the VM
            post-up iptables -t nat -A PREROUTING -i eth0 -p tcp --dport 2222 -j DNAT --to 10.10.10.57:22
            post-up iptables -A FORWARD -i eth0 -p tcp --dport 22 -d 10.10.10.57 -j ACCEPT
    #The VM here has static IP 10.10.10.57 and needs to have it's gateway set as 10.10.10.1 which is the bridge
    Thanked by (2)Not_Oles CamoYoshi
    Nice work man! Glad you got it working. :)
