Ubuntu 20.04 disable cpu core?
edited May 2021 in Help
Hello guys,
I do have a vps with 3 cores which I am allowed to use 75% 24/7. So I thought disabling one of the 3 cores to max out 2 cores 24/7 would be my way to go.
I tried to disable one core by editing the /etc/default/grub and adding maxcpus=2 but after running update-grub and restarting the cpu2 is still online.
Is there anything differnt in newer ubuntu versions so this method does not work?
Thanks in advance.
  • with your last setting , did you try to make a workload that uses all cpu and check from htop what is being used?
    No, I just checked htop to see how many cpus are avaible and took a look at /sys/devices/system/cpu/cpu2/online if it's online. Did not think of it might show up but is not being used.
    420 special, isn't it?
    https://talk.lowendspirit.com/discussion/comment/62861/#Comment_62861
    Do you know you can write to this file?
    Write a 0 and the CPU is offline.
    Thanked by (2)Multi_ ehab
  • BochiBochi OG
    edited May 2021
    If it is a single process, that is producing the load you could use taskset to set its affinity.
    Or create a cpu cgroup with some limits for a whole set of processes and its threads, maybe even in combination with a cpuset.
    Yes, exactly.
    I can do that, but after a restart it's online again.
    google sysctl.d
    Thanked by (2)Multi_ skorous
  • @ehab said:
    google sysctl.d
    Sorry for the late reply.
    I am unable to set the amount of cpu cores with a sysctl config. According to this list the "maxcpus" parameter is a kernel parameter but I am unable to use that in a config.
    I am really sorry but I am kinda new to the topic Kernels and their parameters. Until now it just worked for me ^^
  • Are you sure you're allowed to max 75% of all 3 cores? Linux tends to list cpu usage as percentage of a single core, ie maxing out 2 cores would result in 200% cpu usage.
    Could be that your provider has (rightfully so in my opinion) put the limit below 1 core all the time, since it's a shared environment.
    Thanked by (1)Ouji
    edited May 2021
    If I had €1 for every time I have had to explain that.... well I would not be a millionaire but it would be a good chunk of change..
    People are so quick to look for loopholes to get dedicated resources on a shared resource environment.
    If the host wanted to they will just kill your cpu weight in the back end anyway I guess
    Maybe just ask your host to remove a core for you? If you are confident that is what you paid for it should not be a problem right?
    Thanked by (1)Multi_
  • edited May 2021
    Create a custom systemd service to write the file upon start, and make that service auto start.
    Terms of Service for 420 special: https://hosterlabs.net/tos/
    Archive link: http://web.archive.org/web/20210420230451/https://hosterlabs.net/tos/
    "CPU Abuse is defined as: You might not use more than 75% of a shared CPU resource for more than 72 hours in a given week or 6 straight hours."
    This applies to every plan.
    It's only reasonable to interpret as "75% of all cores", otherwise there would be no difference paying for 1 core or 6 cores.
    Moreover, the provider themselves said "technically yes" when I asked: https://talk.lowendspirit.com/discussion/comment/62863/#Comment_62863
    I know.
    It's like docker run --cpus 0.02, and everything in the container slows to a crawl.
    Oracle Cloud and EUserv are definitely doing that.
    VirMach is probably doing that.
    I have no problem with that, and I even prefer a permanent throttling of every resource.
    I hate having to set CPU limits on every process myself, and still worry about a suspension hammer.
    I read “a shared cpu resource” as a (singular) thread or core.
    I am not just saying that to take an opposing view, that is honestly how I understood it on initial reading so it needs some clarification IMO.
