Cloudflare 1.1.1.1 Private DNS For Windows ?
yokowasisyokowasis Services Provider
I know their website has apps for windows, the thing is. It doesn't work. Some websites still blocked.
The mobile (android apps), works great. It unblock all the websites. Anyone know similar software on windows ?
  • vyasvyas OG
    edited May 2021
    Try 1.1.1.2 /1.0.02 (malware filter) but not 1.1.1.3 (blocks p0rn sites too). I use them for all my devices (even for ivacy vpn)
    More at:
    https://blog.cloudflare.com/introducing-1-1-1-1-for-families/
    Note: 1. I use mac/ linux not sure about Windows
    2. some sites load slow as a dog- but that is generally during high network traffic times. (read: IPL matches streaming, or Friends reunion this week)
  • DNS alone can't unblock sites blocked by your ISP. You'd need a VPN + DNS or a standalone VPN.
    A third-party DNS only prevents your search queries from going to your ISP.
  • yokowasisyokowasis Services Provider
    edited May 2021
    Umm, Yes, but Actuallyu No.
    a Simple DNS change can't unblock sites.
    But, Android Private DNS such as Cloudflare 1.1.1.1, can unblock sites.
  • edited May 2021
    https://www.dnscrypt.org/#dnscrypt-windows
    alternate with edit hosts file and add sites with your records ip and copy to windows system :
    copy /v /y "%HOMEDRIVE%\pathtest\hosts" "%WinDir%\system32\drivers\etc\hosts"
    edited May 2021
    @vyas said:
    Try 1.1.1.2 /1.0.02 (malware filter) but not 1.1.1.3 (blocks p0rn sites too). I se them for all my devices (even for ivacy vpn) some sites load slow as a dog- but that is generally during high network traffic times. (read: IPL matches streaming, or Friends reunion this week)
    More at:
    Does Windows have private dns feature like android one. I can't unblock sites using 1.1.1.1 application on windows. But I can unblock the sites, using private dns or 1.1.1.1 Android apps just fine.
    I don't think android private dns is just a simple dns change.
  • _MS__MS_ OG
    edited May 2021
    Yes, if you use Cloudflare WARP with 1.1.1.1. That's what their app does; create a secure tunnel. I've found Blokada to be better than Cloudflare's app on Android.
    Android's Private DNS is much more advanced than Windows' IP-only DNS.
    For some reason, their windows APP can't unblock sites.
  • SpeedBusSpeedBus Hosting ProviderOG
    Has anyone tried this https://yogadns.com/ ?
    Later versions of Windows 10 (or maybe the insider previews) do have DNS over TLS/HTTPS support
    Thanked by (1)ehab
  • If you trying to bypass Telkom, use adhole.org or ahadns with DoH on your browser.
    You're welcome.
  • edited May 2021
    Did you enable warp in apps setting? There was another project that generated wireguard configs for warp wonder if it's still around
    https://github.com/ViRb3/wgcf
    Also noone still mentioned goodbye-dpi ?
    indihome ? try to use dns with custom port (5353 or 443) or DOH, or dnscrypt, etc
    some indonesian isp force traffic udp port 53 to their dns server (telkom and biznet doing this)
