SSH Port Client Connection
Hi all, I need some hints from you.
My problem is NAT service and port 22 not used to SSH client connection.
I bought a NAT service about 2 months ago and port 22 of SSH client connection is ok.
Last week, I bought a same NAT service and make a SSH conection, however the connection time out, then I open a ticket, and My anwser open ticket help is port 22 not used to SSH client connection
Two days ago, I bought another NAT service, then I got through the conection with IPv4 server with port 22.
I don't know what happen yet, although I have checked the page service in many time. Port 22 is also default port to my server.
Thanks a lot,
  • It is NAT, your assigned external port for SSH for ipv4 is forwarded to your port 22. If you want to directly use port 22 use ipv6.
  • Read carefully the instructions of the welcome email you received from your provider. You normally get an external shared IPv4 and a custom port that is redirect to your SSH port on the internal network.
    Thanked by (2)Amitz Kingzerro
    It seems highly unlikely that you are using port 22 for SSH on a NAT service, please provide more specific information, xxx out the last 2 octets of the IP's and paste the instruction emails or something, I am sure we can help you out.
    Many thanks to @InceptionHosting , and I am very sure using port 22 for SSH on a NAT service.
    Here is IPv4 45.61.147.135 could you check it out when you have spare time.
    And some informations paste from email;
    IPv4 NAT IP Information
    You have been assigned a range of 20 ports along with your NAT IPv4 address and 1 redirection port for ssh.
    The first 20 ports are based on the last octet of your IP, you can use these for anything you want, examples below:
    EXAMPLES:
    172.16.0.3 has the following port range forwarded: 301 - 320
    172.16.0.13 has the following port range forwarded: 1301 - 1320
    If you intend to connect using IPv4, you also get 1 extra forwarded port to your servers port 22 (default ssh port). This is added to your allocated ports.
    EXAMPLES:
    192.168.0.3 has the following port forwarded to port 22: - 321
  • skorousskorous OG
    edited July 20
    @Kingzerro said: Many thanks to @InceptionHosting , and I am very sure using port 22 for SSH on a NAT service.
    That IP may well have ssh running on it but it's not your NAT instance. It says this in the email you quote.
    Thanked by (1)Amitz
  • edited July 20
    That is your public IPv4 address.
    @Kingzerro, what is your local/private VPS IPv4 address?
    If your local/provate IPv4 address 172.16.0.3, then your SSH port using public IPv4 address 45.61.147.135 port 321
    If your local/provate IPv4 address 172.16.0.17, then your SSH port using public IPv4 address 45.61.147.135 port 1721
    If your local/provate IPv4 address 172.16.0.100, then your SSH port using public IPv4 address 45.61.147.135 port 10021
    Thanks @chocolateshirt, It works like that. +1:
    Thanked by (1)chocolateshirt
    @Kingzerro said: I am very sure using port 22 for SSH on a NAT service.
    That was your problem :)
    As I'm tagged in this thread, I believe it was you who also opened a ticket about this where I answered that you should check your service details page for the IP and port to use?
    Get 4 or more NAT servers (mix/match between packages) and get a 30 % recurring discount. https://clients.mrvm.net
  • @mikho said: .. I answered that you should check your service details page for the IP and port to use?
    Is it such a wise idea to display these details in public (albeit as a picture)? :/
    That VPS is not running anymore. And never will boot again.
    Thanked by (1)AlwaysSkint
    Is it such a wise idea to assign <1024 ports to a NAT container?
    As long as it isn’t in use by another application, I don’t see why not?
    It is against the ”rules” but I’ve been doing this for many years now and this is rhe first time I hear that question.
