Windows 10 RDP hangs with " Please wait screen"
Hey folks,
Recently face this issue with my RDP. Does anyone face the same.? Any solution you get guys?
  • can you access vnc? is it the same? did you try to reboot from your provider cp?
    by the hair on your chin , change to Debian / alpine ...
    Thanked by (1)Sanjue007
    Hey thanks for the suggestion. Have tried rebooting by the cp every time this appears but this is more like 3 or more times a day. So the rebooting every time won't work.
  • connect with VNC and reboot- is it the same?
    Have you tried a different client/PC to rue out a local issue?
    It could also be dead sessions not being cleared properly, I believe desktop versions only allow 2 connections.
  • Means someone has already connected and is putting in the work ;)
  • mikhomikho AdministratorOG
    Like many already mentioned, if you are not running the RDS service, only 2 administrative logins are allowed at the same time.
    If both are active, one has to be disconnected.
    If noone answers the question, you are stuck, waiting for it to be released.
    If thats not the case, try connecting without attaching client printers in the rdp client.
