If Anyone is interested [site/server specs]
12357
    I also just ran it through a load impact test, it handled a synthetic load of 231 requests p/second with an avg latency of 13ms, so that allows some room for growth with the current specs :)
  • havochavoc OGContent Writer
    What did you use to load test it?
    Recently played with loader.io vs wordpress a bit. Can't take a lot even on a beefy machine...until you enable caching that is.
    havoc said: What did you use to load test it?
    Just a free test on loadimpact https://loadimpact.com/
    I will try loader.io
    Thanked by (1)flips
    edited November 2019
    running loader.io 50 client sim now as I update this.
    edit:
    no failures but it did slow down to 1308ms load time at the end.
    Thanks for showing me that tool, great for testing.
    Thanked by (1)uptime
    Yeah initial plan was to spin up some azure servers and use the siege app. Couple of those could sink anything.
    ...but that would have looked like a DoS attempt so yeah no
  • SpeedBusSpeedBus Hosting ProviderOG
    Update pls <3
    edited December 2019
    @SpeedBus said:
    Update pls <3
    Only updating on Fridays now :)
    preview:
    Thanked by (3)SpeedBus uptime poisson
    @SpeedBus said:
    Update pls <3
    Disk remains at 5G or was upsized? iirc last update had 80% usage
    @SpeedBus said:
    @SpeedBus said:
    Update pls <3
    still 5GB
    # df -h
    Filesystem      Size  Used Avail Use% Mounted on
    /dev/vda1       4.9G  3.5G  1.2G  76% /
    Just did a bit of house keeping.
    Thanked by (3)uptime SpeedBus vimalware
    Do you intend to allow upload to disk? It will build up over time
    Yep, I have some ideas on managing that for the long term, like pushing images through imgur (transparrently) when uploaded and having a link kill life on none image extensions of 1 year.
    Thanked by (1)cybertech
  • WSSWSS OGRetired
    Or, you know, moving them onto thttpd on a 486 out of Kuala Lumpur with a 3GB Maxtor on dialup to get rid of the kids.
  • Please keep the uploads around. Imgur deletes inactive ones which means that old forum images are broken all over the web, not good.
    willie said: Please keep the uploads around. Imgur deletes inactive ones which means that old forum images are broken all over the web, not good.
    Fair one, I will probably have a separate server for images then or put some cdn offloading in place, I will work something out.
  • There is another issue with imgur:
    I know about at least 3 forums that have been blocked by imgur - they are considered as marketplaces, because some threads contain offers. If that happens to LES, then all images would be lost...
    Thanked by (2)uptime Ympker
  • mikhomikho AdministratorOG
    I know someone you could talk to on howto NOT setup a cluster. ;)
    If you are interested in something that isn't imgur for images, I run https://drop.cm/ as a side-hobby, and wouldn't mind some usage of it :)
    EDIT: If someone wants to connect ShareX to it, that's possible aswell, https://drop.cm/Dropcm_ShareX_instructions.pdf
  • AnthonySmith said: Yep, I have some ideas on managing that for the long term
    You would be surprised to see how little space uploads consume on Host Balls, even after almost 2 years.
    imgur is in need of an alternative, but tbh the main attraction of imgur appears to be missing - anonymously drag drop an img and hotlink it.
    Arguably not a particularly sustainable business model so can see why you'd not want to do that
    Thanked by (2)uptime SpeedBus
    Yep, the server logs take up more space, so far I would say its been about 100mb p/week and that's essentially uncompressed as vanilla does not do a great job of that but @Phill had some good ideas to reduce that by as much as 90% in same cases without loss of experience so I will be implementing that.
    Thanked by (1)Phill
    bingo, pretty much want to keep it as a side-project with least work/time going into it, just wish at times the .cm domain was cheaper.. wayy cheaper.
    hmm...alternative...allow anon upload & hotlinking but just from specific domains? e.g. this forum. Not 100% sure how to do that technically tho
  • FHRFHR Hosting ProviderOG
    BunnyCDN!
    Will update on Friday, :)
    Thanked by (3)Amitz AlwaysSkint uptime
  • Update time! Update time! =)
  • Please specify disk space and memory capacity in future updates
    The server a 512mb KVM with a 5GB disk.
    Thanked by (2)Ympker dahartigan
  • WSSWSS OGRetired
    What if he moves it to a CC VPS?
