Microsoft Announces Azure spot pricing
havochavoc OGContent Writer
Could be interesting for experimental uses & quick disposable stuff. AWS has similar but I prefer Azure
https://azure.microsoft.com/en-us/blog/announcing-the-preview-of-azure-spot-virtual-machines/
  • hyperexperthyperexpert Hosting ProviderOG
    This is very similar to their B series in terms of intended functionality. I welcome any discounted services from Azure with open arms.
  • Those prices don't seem so great compared to hetzner cloud or scaleway bare metal.
    Thanked by (2)vpsgeek Hetzner_OL
  • havochavoc OGContent Writer
    Yeah the specialised VPS providers will always win that fight.
    Or rather Azure can afford to price their stuff higher because the value proposition isn't lowest cost, but rather integration.
    They've got 100+ individual Lego pieces in their Azure offering. And often you need a VM somewhere in the middle of it to build something cool.
    Anyway...going slightly off LES topic I guess. Very excited for this though, esp if that 80% discount holds steady (probably won't as more people take up spot instances)
  • The 80% is likely to hold imho. It is around that level for AWS and GCS, depending.
  • havoc said: quick disposable stuff.
    I usually use Vultr for that. $0.004/hr on their cheapest (IPv6-only) plan.
    Thanked by (1)WSS
    In fairness part of the reason I'm so stoked about this is MSDN sub.
    If your employer gives you access to MSDN you'll have Azure credits...150usd/pm...which is a lot of server (for non-commercial use!)
  • Thanks @havoc , useful information.
    No longer available in most locations?
  • WSSWSS OGRetired
    You are aware of the basis of Low End Spirit, yes?
    I am aware. I don't think @AnthonySmith or @mikho would do BGP on their LES though.
  • WSSWSS OGRetired
    Would probably take some crazy bastard like @cam for that.
