VirMach Tokyo 21.85/USD/y (pre-order).. finally! orz
Network seems to be under somewhat high load, apart from mediocre speeds, ping isn't exactly stable either.. perhaps everyone else is running YABS too right now?
Anyway, it's more than enough for idling
Ubuntu 22.04 installer, loaded via either netboot.xyz or grub loopback, does not work in 1GB RAM.
Hence, I install Ubuntu 20.04 cleanly and then immediately run do-release-upgrade -d.
Interested in adding this to the repo. Seems to work fine on all the machines I've tested. Would you like to PR the changes so that you're credited? Stick the three lines in just above the Processor line I'm thinking.
This is a Google Cloud instance.
Google Cloud charges $6,000+/month for the disk alone. Only the disk. I am not joking.
With "Extreme" persistent disk:
With "SSD" disk:
So yes, I just ran a fio test on a $6,000+/month disk and well
The funny part is that the server itself is cheaper, you're able to get 768GB of actual RAM for cheaper than this 500GB "extreme" disk
I guess I really should think about letting this lapse this year, even if it's just to get the same thing again, as the current KS-1 has double the RAM and disk for the same price. But I've had this for about 9 years and it'd be like getting rid of an old pet or something!
Come on, post yabs with provider/pricing etc.
ssd nodes
Cheap VPS starting at only $11/year (aff) | Spicy KVM Deals (aff) | Dev Tools.
There’s your answer. Try contacting support I guess
AMD EPYC™ L from server-factory.com
central.so rebench
AlphaVPS OVZ Sofia
HostTheBest.com - Utah NVME VPS - Plan 1 / UTAHKVM4GB - $4.99 first month, then $9.99/month (not worth it!)
SoYouStart SYS-2-SSD-32 (Xeon D1541, 2 x 450 NVMe, GRA datacenter)
Nexril 1GB Dallas, Ubuntu 20.04 vs Ubuntu 22.04: Geekbench score increased by 4~5%.
Link to previous benchmark: https://talk.lowendspirit.com/discussion/comment/58999/#Comment_58999
Ubuntu 20.04 (zram swap, ext4 filesystem)
Ubuntu 22.04 (zram swap, xfs filesystem)
.ServerFactory aff best VPS; HostBrr aff best storage.
@yoursunny gets a credit of ten push ups or an extra month of storage on Lunarmach Eclipse plan for his work.
Squats are the new Push-ups
No need for PR you can add it, ill leave the place for you where you think it will fit best Cheers
This looks like the work of SuperVirBot.
96 cores, with 997 each = 29k? uh wat.
GeekBench might not scale up far enough for 96 cores, maybe ~32 is the max it's written for.
Anyway: VirMach JP 4GB special
But this is benchy not yabs 👀
jk
Hostcram
Killer Core: KVM-3C
Oneprovider (Dedicated Cloud Instance) London
EPYC 7401P (2 vCore)
8GB DDR4
125GB SSD(NVMe)
With "SSD" disk:
Sir, this is a Wendy's
Appreciate it, mate! Just added it into the script and pushed the changes live
hosthatch lax new bench
VirMach - Amsterdam - $11.58 USD Annually
just patiently waiting for mine 😎
