Let's Encrypt Revoking 3 Million TLS Certificates Issued
The most popular free certificate signing authority Let's Encrypt is going to revoke more than 3 million TLS certificates within the next 24 hours that may have been issued wrongfully due to a bug in its Certificate Authority software.
The bug, which Let's Encrypt confirmed on February 29 and was fixed two hours after discovery, impacted the way it checked the domain name ownership before issuing new TLS certificates.
As a result, the bug opened up a scenario where a certificate could be issued even without adequately validating the holder's control of a domain name.
The Certification Authority Authorization (CAA), an internet security policy, allows domain name holders to indicate to certificate authorities (CAs) whether or not they are authorized to issue digital certificates for a specific domain name.
Let's Encrypt considers domain validation results good only for 30 days from the time of validation, after which it rechecks the CAA record authorizing that domain before issuing the certificate. The bug — which was uncovered in the code for Boulder, the certificate signing software used by Let's Encrypt — is as follows:
"When a certificate request contained N domain names that needed CAA rechecking, Boulder would pick one domain name and check it N times." In other words, when Boulder needed to parse, for example, a group of 5 domains names that required CAA rechecking, it would check one domain name 5 times as opposed to checking each of the 5 domains once.
The company said the bug was introduced as part of an update back in July 2019.
This means that Let's Encrypt might have issued certificates that it shouldn't have in the first place, as a result of which it's revoking all the TLS certificates that were affected by the bug.
source: https://thehackernews.com/2020/03/lets-encrypt-certificate-revocation.html
Thx. I got a mail from them this morning notifying that certificate for one of my (sub) domains would be revoked. This was in a vps no longer active so no harm done so far.
Waiting for updates on any certificate issues through LE on DA
Squats are the new Push-ups
My understanding is that if you have DA set for automatic updates it will renew all effected LE certs during the system cron update. If you don’t have auto updates I think they need to be renewed manually.
Just to add:
No emails for me. Did a check for my domains and they seem OK. Wish they had an API for this. Thanks angstrom.
No emails for me either, but then again, I don't think that they have my email address! I use
acme.sh
, which is a third-party client.In any case, only one of my certificates is affected.
DA also offers a script for hosts to automatically provision missing certificates which I will be using assuming I haven't missed anything.
MichaelCee
Love the short notice. That’s why the commercial alternatives are still alive. I just downgraded it in my mind from production ready status.
Clouvider Limited - VPS in 6 datacenters - Intel Xeon/AMD Epyc with NVMe and 10G uplink! | Dedicated Servers
One could argue that the short notice is good since it will revoke all of the falsly created certificates.
Yes. From that perspective, but clearly these kind of issues make it not quite production ready, for my liking at least.
I did check all mine yesterday and they're all ok; I find excessive to revoke some certs for an hypothetical violation of CAA guidelines. Most alternatives (commercial included) don't even care about CAA or consider it experimental/optional. Also, LE certs are short-lived enough. The corrective action taken seems excessive.
Let's Encrypt certs don't last very long to begin with. Why not just selectively revoke bad actors, and let the problem solve itself as they expire on their own?
sorry it's our mistake, but now it's your problem .
But because it is free* you can get a new one at no additional cost.
*Frustration, time and effort not included under definition of free.
Looks like they have postponed it.
https://community.letsencrypt.org/t/2020-02-29-caa-rechecking-bug/114591/2
No commercial CA would act like this. More serious violations would be/had been ignored if money or customer satisfaction was involved.
Since they don't have "customers" and are nearly alone in the free certification market, they can afford to impose their rules even at a great cost for their users.
Here's hoping for some more competition in the DV market.
You mean, like Symantec?
You mean, like ZeroSSL or Comodo?
No, there is a middle ground.
No, like Buypass. Or the now disgraced WoSign/StartCom.
I almost said WoSign, but then I figured I'd be piling it on a bit thick.
I have one affected certificate, but I was waiting to see when it would be revoked. At this time, it hasn't yet been revoked.
ZeroSSL is based on Let's Encrypt. I like using their Perl script to get LE certs when Python isn't part of the base install.
https://zerossl.com/ssl-faq.html#Are_these_certificates_really_free_or_is_it_just_a__free_trial__
You know we like it thick.
