Singapore VPS - 40% off recurring | KVM & OVZ, Powerful CPUs, ECC RAM, NVMe Disks, DDOS protected
Promo valid till 31/1/21 stock is less.
✅NVMe SSD Disks in RAID + ECC RAM
✅Singapore Datacenter
✅1Gbps ports
✅Free Remote Backup
✅VNC access
✅Custom ISO - netboot
✅99.9% uptime
✅Virtualizor control panel
✅24 hour money-back policy
KVM plans - coupon TriptoSG
VPS - KVM1G SG
1GB DDR4 ECC RAM
1vCore @3.7+Ghz
5GB NVMe SSD RAID 1 disk
1 x IPv4
125GB High-speed Bandwidth per month
$1.8 Recurring - Order Now
VPS - KVM2G SG
2GB DDR4 ECC RAM
1vCore @3.7+Ghz
15GB NVMe SSD RAID 1 disk
1 x IPv4
250GB High-speed Bandwidth per month
$3.6 Recurring - Order Now
VPS - KVM4G SG
4GB DDR4 ECC RAM
2vCore @3.7+Ghz
25GB NVMe SSD RAID 1 disk
1 x IPv4
0.5TB High-speed Bandwidth per month, then reduced speeds.
$7.2 Recurring - Order Now
Coupon TriptoSG valid on all plans
See all KVM plans >>> https://my.webhorizon.in/order/main/packages/vps/?group_id=12
OpenVZ plans - coupon TriptoSG
VPS - VZ256 SG
256MB DDR4 ECC RAM
10GB HDD RAID 1 disk
1 vCore @3.5+ Ghz
1 x IPv4 + /112 IPv6
0.25TB High-speed Bandwidth per month, then reduced speeds.
$7.2/YEAR Recurring - Order Now
VPS - VZ1G SG
1GB DDR4 ECC RAM
30GB HDD RAID 1 disk
1 vCore @3.5+ Ghz
1TB High-speed Bandwidth per month, then reduced speeds.
$14.4/YEAR Recurring - Order Now
See all ovz plans >>> https://my.webhorizon.in/order/main/packages/vps/?group_id=29
Hardware for KVM plans -> Intel® Xeon® E-2276G Processor @ 3.8 Ghz server grade cpu with Intel NVMe SSD drives datacenter grade
Hardware for OVZ plans -> Intel® Xeon® Processor E3-1270 v6 @ 3.8 Ghz server grade cpu with sata3 hdd datacenter grade
Thank you.
Hope the coupon still available tomorrow
Email for £1/m (aff link)
@Abdullah any plan to offering IPv6 on KVM plan?
@Abdullah Is there looking glass for Singapore? Thanks
For this promotion,
Plans 2GB RAM & below
http://sgp3.lg.webhorizon.in
Plans 4GB RAM & above
http://sgp2.lg.webhorizon.in
https://webhorizon.net
The coupon will be mostly.
Except the 1G plan it has only 2 stock rn, you can order it now & pay in 24 hours. ?
It will be, I'm looking into that.
Just need to figure some things out.
Meanwhile HE tunnel can be useful.
Just need the coupon. Will get either get 4G or 6G plan
I have extended this to all NAT VPS plans too in Singapore.
VPS-NAT256 (SGP)
256MB ECC RAM
1vCore @3.2+Ghz
4GB disk
1 x IPv6 /80
1 x NAT IPv4 (20 usable ports)
250GB @ 1Gbps per month
$4.2/YEAR Recurring - Order Now
VPS-NAT512 (SGP)
512MB ECC RAM
1vCore @3.2+Ghz
7GB disk
1 x IPv6 /80
500GB @ 1Gbps per month
$6.6/YEAR Recurring - Order Now
VPS-NAT1G (SGP)
1GB ECC RAM
1vCore @3.2+Ghz
14GB disk
1 x IPv4 + /80 IPv6
1TB @ 1Gbps per month
$13.2/YEAR Recurring - Order Now
Coupon to be used: TriptoSG
LG: http://sgp3.lg.webhorizon.in
Got the 6G and NAT256
waiting special love of 40% recurring for
https://my.webhorizon.in/order/config/index/BF/?group_id=21&pricing_id=307
Hello sir. Just want to ask if this plan is still available. It shows "Some items have been removed from your cart because of package restrictions."
okay that's an already discounted plan sire!
It went out of stock, will be adding more in sometime.
Aww. I'm a bit late. Thanks for your reply though. Much appreciated! ?
Added some more stock @mainwindow
Wow! Just grabbed one sir! Thank you very much! I've been waiting for lowend NAT in SG for quite some time now! ?
Order #:600f4b139a298
Grab it fast om
Sultan Muda - Amazon Store
Ordered a NAT512 thanks! Order #: 600f6f81d05a8
Had an issue with the payment and accidentally created 2 orders apologies. Managed to pay for 1 and cancelled the dupe I think.
great!
That's alright
