No, for some good reasons :
1. Newly registered (5 months old).
2. No control panel, only SSH.
3. No IPMI.
4. Nulled WHMCS.
5. No english on main website, probably the support team can do basic english.
Testing *experimental* ARM-compatibility using a Raspberry Pi 3.
Disk speeds are very stronk! And I could have taken a nap during the Geekbench test. Kept getting under voltage warnings, so I'll have to find a different power adapter for it. Anyways aarch64 support is pretty much done, now need to work on aarch32/armv7 when I have some more time.
@sonic
network tested aren't accurate as I've just been limited to 6mbit/s
Oh that's good result enough, going to take 1
yeah I think the NVMe is good. looks like a 2680v3
Which provider is that ? Nice exotic location!
Thanked by (1): c1vhosting.
Powered by LinuxFreek.com
https://zappiehost.com/
WSL 2 on my Ryzen dedi
Speedtest results are pretty obvious since this dedi only have 1000Mbps port
NexusBytes Entry-3G
Sultan Muda - Amazon Store
Testing out Slackware in Frankfurt:
As I'd been updating templates, I thought I'd work towards adding a Slackware template too.
hostsolutions still working after few months:
Local provider $28.75 dedi
Email for £1/m (aff link)
Figured I had to grab one of Zappie Host's New Zealand KVMs
Website: thomassen.sh
Inception Hosting
Storage VPS
Phoenix AZ
anynode $15/year promo
before it goes over to buyvm
is the provider disclosable?
https://webhorizon.net
3. No IPMI.
4. Nulled WHMCS.
If you want to look around, https://kakab.net
Update pushed to the YABS repo to incorporate the latest fio, iperf3, and Geekbench 5 releases.
Give me a shout if anyone has any issues to report.
1.75$/month OpenVZ from dedipath.
It provides 2 IPv4 so I give it a try, then I feel it is slow.
Scaleway France Stardust, 1GB, 0.30€/m
Scaleway Netherland Stardust, 1GB, 0.30€/m (without IPv4)
how does it work out to be 0.30 monthly?
Remove the IPv4 as I said above, VAT may apply so a few cents more.
Link to order. Thanks.
$5/lifetime, much prem
https://vortexnode.com/superdeals
you really reminded me of that time.
Too much.
Where is ARMYABS?
Coming soon to a repo near you
I have to clean it up a bit first and take it through a few more test runs, then it should be good to go.
aliendata / dataideas
shared xeon storage vps $5 monthly
disk test with the 120gb ssd storage portion rather than the 20gb nvme boot
