[request] 1 dolar VPS with IPV6
Hello!! looking something really cheap, just to test if my vpn works.
i dont have ipv6 (damn isp) but with openvpn i make it work.
i want a cheap vps with ipv6 as a personal vpn (just to have ipv6)
i ordered a nat servers, but still not get the info from provider so, any other? preferably on USA
Just for clarity, you want to pay $1 p/month or $12 p/year?
if you only need it to test then use one of the free amazon tier ones https://aws.amazon.com/free/
A provider is essentially paying you to use it (none nat) when it is just $1
hey! dont get angry.
Not angry
Was trying to help.
If you just need one for short term test i will give you one, no need to pay.
i dont know, you made me think about it....
let me wait for the nat, if not, i send you a message
Nat is just fine if you need ipv6. I am doing the same thing on @mikho 's box
Nat vps + wireguard + pi hole is all you need.. 4 usd per year for 128 MB vps is more than enough..
i am just waiting the nat vps, i know what to do. just want to confirm it works
pi-hole for what? lol
dont get angry
Take an Amitz a day and temper/anger will never be an issue.
Pi hole inside nat or standalone?
Try Tunnelbroker.net from HE, it's free. You do need a public IPv4 though.
and dont get angry
instructions unclear
pihole stuck in popo, please advice!
ain't mad, just saying ... @Amitz
Also ... with regard to the ipv6 (and not exactly responsive to your $1 request, but maybe for future reference) - @freerangecloud is all about the ipv6 support, and they do some nice deals. Maybe they'd consider an ipv6-only offer, who knows?
HS4LIFE (+ (* 3 4) (* 5 6))
Of course pihole inside nat..
Does wireguard run on OVZ7?
Got a few inceptionhosting nat vps
Also might do well to spin up an hourly LunaNode - I think their ipv6 setup is pretty smooth
Not sure what the minimum initial deposit is, but it might be just $5 (or $10?)
ISP blocks also ping:
IP is not ICMP pingable. Please make sure ICMP is not blocked. If you are blocking ICMP, please allow 66.220.2.74 through your firewall.
$3.5 vps from vultr worked great, using this:
ipv6 done
IPv6 connectivity
IPv6 Supported
Address 2904:z880:2:n1::13b:e001
Type Native IPv6
SLAAC No
ICMP Reachable
Hostname None
ISP Chupa
hey yo!
dont get angry
Did anybody say Angry?
Squats are the new Push-ups
Of course it will work, but not on kernel level..
Incidentally, this is why I asked about your requirement for KVM in your other thread but you ignored me.
EDIT: ( comment for iandk not chocolateshirt )
