Fixed... turns out www was still pointing to our old InceptionHosting VM IP. Sorry y'all. I've requested a re-index on Google so hopefully our search result gets updated shortly.
Thank you for finding this! And yes this could have easily been avoided if I had double checked our DNS entries after switching everything over months ago Live and learn, I suppose
Thanks to @Amadex for posting the issue! Thanks to @Mason for a prompt investigation, a prompt fix, and a simple, clear explanation of what happened! LES is great! Woudn't it be equally great if other sites handled their issues similarly?
Strange... I'm seeing this too and the cache contents are for "turkmenportal.com", not here. So that's confusing.
Looks like we are having issues with the "www" subdomain, so I'll see what's going on in the Runcloud settings.
ЛоwЕндСпирит
Amadex • Hosting Forums • Virtmach • Wie ist meine IP-Adresse? • AS215325
Update --
Само Руси могу да варе под водом!
Glad it was noted and (will be) fixed.
